Very cool bit of software you have here - thanks I’m having some issues setting up.
In config_extended.php I have:
$pageroot = '/newsletter/lists';
My URL is:
https://foo.com/newsletter/lists/admin/
…yet I get this error:
The pageroot in your config does not match the current location
Check your config file.
Am I being dumb and missing something?
Thanks!
Andy
the pageroot is the ‘path’ relative to your website root address… so in your case, if the page on the website is /newsletter/lists’, then you have it specified correctly.
You should have that value in your /newsletter/lists/config/config.php config file.
if you have it in your config_extended.php file, it won’t make a difference (That file is an example of settings you can put in your config.php file.
Dan
Ahhh man … now I feel like an idiot! I was editing the _extended file thinking that overwrote the config.php stuff. I didn’t realise it was just an example of all the different config options
Thats all working great now - thanks I’ll keep playing
