HI there, I want to know where exactly is saved (I mean the absolute path inside list hierarchy) the logo file where I upload it in preferences?
Normally I think that depends on where you defined it in the config.php file, but if you view the page your logo is on, then right-click the image, and View Image Info, you should see the path to your image.
