My webhost is allowing me to send only max 180 emails per hour.
I use cron to process messages every 5 minutes.
Can i use batch_size, batch_period and domain_batch parameters like with older phplist (now i am using version 3.2.4) and what is the correct values for each of the paramaters (if those are wrong)?
This is what i used with older phplist:
define(“MAILQUEUE_BATCH_SIZE”,15);
define(“MAILQUEUE_BATCH_PERIOD”,60);
define(‘MAILQUEUE_THROTTLE’,1);
define(‘USE_DOMAIN_THROTTLE’,0);
define(‘DOMAIN_BATCH_SIZE’,1);
define(‘DOMAIN_BATCH_PERIOD’,120);
define(‘DOMAIN_AUTO_THROTTLE’,1);
