Hi, i’ve installed phplist on my server.
I want to create different autonomous users with different phplist profiles.
It’s possible or i have to install multiple times phplist?
Were i can find instructions?
thanks a lot
thanks a lot
You can make sub admins, and they can only see their own lists and subscribers, but the data is shared between them - it’s designed for members of the same marketing team, not for separate companies etc
OK thank you very much.
I have 3 different companies and I wanted to manage separately.
Maybe it’s better to make 3 different installations
Yes, or offer them .com accounts and charge them 20% extra or something.
Those are the old phpList 2 docs, I have no idea if that bit would still work. I would assume not but you can try Feel free to write about it if you do.
Are you all set to deal with the deliverability/blacklisting stuff?
