I cannot get the invite plugin to work correctly. I activated it and used the provided “Do you want to continue receiving our messages?” campaign to send to a new private list with two addresses for testing. The addresses were NOT blacklisted after sending the campaign. (I thought that is what should happen, and the blacklist flag would be removed only if the addressee clicks on the confirmation link.)
What am I doing wrong?
I am using phplist v3.4.2.
Thanks.
Hi, have you set the type to “invite” on the format tab?
Ah, that is what I missed.
It is counter-intuitive (because “Invite” is not a format) but it
works.
Thanks very much !
– D.R.
