I see only a blank page. Can you please confirm for me that this is the correct address to see your phpList installation?
Must admit that to me personally, it is a weird youâre using, but thatâs just me, sorry.
Worst case scenario, consider allowing me to view your webspace and Iâll see if there is anything that I can spot as to why you are having so muych trouble with this.
re: âWorst case scenario, consider allowing me to view your webspace and Iâll see if there is anything that I can spot as to why you are having so much trouble with this.â
Yes, I will give you ftp access to the GoDaddy hosting service (the first one, which I am still trying to run).
Is that all you need?
If âyesâ then give me an email so that I can send host/un/pw to you.
If âno, thatâs not what I meant,â then what do you mean by â⊠allowing me to view your webspaceâ
Remember, this is not a CMS site, this is a Static-HTML website. Okay?
re: âbest-equestrian-footing-fibers.net/pHp_list-newsletters/lists/â
No, that is not my installation.
I deleted everything and installed it into the default location.
(chrome) The best-equestrian-footing-fibers.net page isnât working best-equestrian-footing-fibers.net is currently unable to handle this request.
(MS Edge) HTTP 500 error
Thatâs odd⊠Microsoft Edge canât find this page
This page canât be displayed, because this siteâs server might be under maintenance or there could be a programming error.
(MS IE) The website cannot display the page | HTTP 500
This error (HTTP 500 Internal Server Error) means that the website you are visiting had a server problem which prevented the webpage from displaying.
(Firefox) Blank Page - no 500 error.
After weeks of trying, I went out and installed phplist on another server, in the default manner.
The host is Webmasters.com (using their own controlpanel.com, Linux/Apache servers).
LISTS location » bestfooting.net/lists/
Admin URL » bestfooting.net/lists/admin/
Same results.
Question:
Are there ANY other settings in the config.php file which need to be edited - other than these four (with the "# "changed to â/â)
/ what is your Mysql database server hostname
$database_host = âlocalhostâ;
/ what is the name of the database we are using
$database_name = ââ;
/ what user has access to this database
$database_user = â****************â;
/ and what is the password to login to control the database
$database_password = â**************â;
The odd thing: I installed & ran phplist 10 years ago, and there was no issue. I donât think I got dumber during that time, but maybe Iâm wrong.
Are you sure?
A new user can login, click on your username, and get the option to send you a message?
When I click on your username and it does not offer âmessagesâ - just a list of your posts, badges, etc.
Tried it with Chrome & Firefox - no can do.
Why donât you just send me an email?
It is in my profile, or you could go to MarkRector.com and click on the link: (Insert your comments here).
Okay, itâs working and I discovered the reason why it was not installing: W10 filepaths/filenames were either âToo longâ or âA buffer was too smallâ in the FTP client.
I changed the filing system location on my LOCAL computer - to shorten the filepath/filenames - and suddenly the entire /lists folder fully uploaded without any missing files or folders.
I ran a test case at another URL, and my solution worked perfectly - first time out of the box within minutes I had it up and running.
If you are interested in the permanent fix to the Windows 10 Professional problem, when using an FTP Client application, please do not hesitate to contact me.
I also created a âfixedâ zip file, which you may wish to offer other new users, it is a simple yet elegant solution to the US/UE issues which many of us wil encounter, going forward. Iâve already created the ZIP file which others may use, if the want: simply upload the ZIP file into your ROOT directory, unzip it and run the program. No moving files/folders or anything.
Let me know if youâre interested, DragonRider.
mit freundlichen grĂŒĂen/best regards,
mark
The installation manual page should specify what version(s) of PHP are supported - and what all the prerequisites for phpList are. Or at least a web page thatâs kept up-to-date with this basic info thatâs necessary for an install!
Is phpList compatible with PHP v7? Weâve been running 5.6, but our host is moving to 7.0 as a default, and 7.1 is available.
@tlhackque Thanks for the suggestion â the manual page has now been updated and the change should be visible shortly.
Regarding PHP7, yes, phpList 3 and 4 run and are automatically tested against PHP 7 and 7.1. You can see all PHP versions that phpList is tested against on Travis: https://travis-ci.org/phpList/phplist3
The System Requirements page (https://resources.phplist.com/system/start) says: âPHP 5.3.3 or laterâ.
I spent hours trying to install version 3.3.1, getting only a blank page without any error notice, until I noticed that in two files (connect.php e defaulconfig.php) is used the random_bytes() function, which exists only in PHP 7.
Please update the requirements page!
@Tomark Thatâs strange because PHP 5.3 and later are tested via Travis: https://travis-ci.org/phpList/phplist3
There are compatibility libraries included which are used when random_bytes() isnât available, but Iâm not sure if they are used in all instances (such as the ones you mentioned).
Notably, remote processing isnât tested via Travis AFAIK.
