I am having an issue with the dialog box for initialising language, opening up on every click of a link in phpList.
Ideally once you login it should show that pop dialog box Initialising language once and then not show up again.
But every time that i click any link in phplist it pops up each and everytime and it takes so much time to load. Which gets very irritating and time consuming.
Can anyone suggest what can be done to fix it?
I am using phpList version 3.2.1
It would really be of great help.
Thanks in advance.
