I have been running a very old version of phplist. I just installed the latest version on a subdomain to learn it a bit before importing my subscriber list.
I used to have an addon or plugin that allowed me to pull html into my email using a tag.
[PHP:$html = implode(’’, file(’/home/public_html/xx.txt’)); return($html); ]
I can no longer find it. Any idea?
Maybe what I’m looking for isn’t an implode plugin, but a PHP plugin?
@StevenSchlossman Do you still have access to the old phplist? If that tag is being processed by a plugin then the code might be in the admin/plugins directory. Otherwise it might have been a custom modification to the phplist code.
phplist currently doesn’t provide a way to include a file in this way.
I looked in my plugin directory. It’s not there. I probably added it to the code somewhere. It was so long ago. I’ll look at the files and hope that a modification date pops out.
Thank you.
@StevenSchlossman If you are trying to construct the complete email outside of phplist then you can probably do that just with php
Rename the template to a php file, e.g. template.php
Use php include statements to include the additional files
<html>
<body>
<div>some html</div>
<?php include 'include1.html'; ?>
<div>some more html</div>
<?php include 'include2.html'; ?>
</body>
</html>
Then on the Content tab use “Send a webpage”.
Good idea but after looking at your content area addon, that works even better.
In the past I’d include text files in my message., But before I could do that I’d still have to edit them slightly to clean up some html.
With content areas I can copy and paste into the campaign text and edit it there.
BTW, when I <?php include 'include1.html'; ?>
some more html
<?php include 'include2.html'; ?>, it gets commented out.
I can add .php to a template name?
@StevenSchlossman I don’t understand what you mean. My previous suggestion was for use with “sending a web page”, it is not going to work with loading a template into phplist, if that is what you are doing. phplist doesn’t treat templates as containing embedded php code.
Gotcha. I wanted to import a page into the campaign message. Your Content Area addon is going to workout perfectly. It’s a couple extra steps but in the long run, editing the message is going to be easier. Thank you!.
