phpList.org
Image Not Visible
Hi, When I send test mail contains image and text. Footer images okay but inserted image is not showing?
Any idea how can I resolve it?
I use version 3.5.5
thanks
One assumes you are not using the full path to the image, or it is on your computer, and not the internet?
What do you see if you right-click on the “box X” and look at properties, does that point to where your actual image is stored?
You should also double-check if the image link is using https instead of HTTP, sometimes that’s what causes the issue.
Hi @Suela,
Thank you for your answer.
Yes I have checked image link was “/admin/plugins/CKEditorPlugin/kcfinder/upload/image/optikfuar2020-mav.png” and image was invisible.
But I changed link to “https://ebulten.demirkayaoptik.com/admin/plugins/CKEditorPlugin/kcfinder/upload/image/optikfuar2020-mav.png” and image was loaded fine.
For future how can I change that URL for using https? I mean permited resolve?
Hi, this thread gives the details of how you can change the default protocol used:
