When i try and import the list of emails from a CSV file it consistently won’t map the attributes/columns - I’ve only got two columns - name and email address - when I map the Email I get a test output but it includes the name - i have no option to map the name column as well/
I’ve got screenshots of the problem
Kind regards
Gavin Crombie
Gavin,
You would want to check your file format. I would switch over to a tab delimited file, and make sure it’s in a ‘windows CR/LF’ format. Although not necessary, I suggest putting the email in the first column, make sure there are headers in the top row, i.e. ‘email’ tab ‘full_name’, and then try importing the list, make sure the ‘test output’ is selected, it will ask you how to map the ‘full_name’ field (create an attribute), then you finish importing the list.
Dan
Thanks Dan - I shall try that and see how I go
I managed to get the test output but it has the name beside the email address - which I don’t want - or is that how it is always.
Kind regards
Gavin
Sorted - thanks a lot Dan!
