I notice that 1 of my subscribers is receiving the text format version of a campaign. How would I determine which subscriber that is?
Thanks in advance
Al
Thanks in advance
Al
@sunriseal You can export subscribers of the list to which you sent the campaign. One of the columns will be the html/text format.
I tried that while awaiting a response and saw what you indicated. However, I hate working with excel sheets so decided to see if anyone could suggest something else
Guess I will just have to give it another shot…
Thank you for the response
Al
Why do you need to identify them? If it is because you want them all on html, there is a button to do that in reconcile subscriber page.
You may also be able to spot them in the open / click stats, not sure.
Why: Just wanted to make sure that it was not one of those that I added
and perhaps caused it to be test rather than HTML.
I will have to check out the button on the reconcile page…
I was able to find it using Duncan’s suggestion and selecting only a few
fields…
Thank you to both you and Duncan for your suggestions!!
Al
