Hello. I recently updated PHPList and the HTML editor is no longer showing. If I view an old campaign I can see the HTML version but can’t see the source code. If I start a new campaign I the HTML editor does not show. Any help? Thanks.
p.s. my config.php file has not changed and it is set to “USEFCK”,1
@jnasta ckeditor has replaced fckeditor so you should use that. If you have any trouble with ckeditor then the documentation page might help. You can find it on the Manage plugins page where most plugins have a documentation link.
The batch settings in the config file are unchanged.
