Tell me how to use graphite library to phplist.
Thank you
Thank you
The statistics are generated by queries from the database. You would need to look at the existing phpList code, figure out what the queries look like, and then use that as a starting point for sending the data to graphite.
In the mean time, @duncanc has written a plugin called Campaign Statistics plugin, you might want to check that out, either for use as-is, or how to make a plugin, or as a starting point for your graphite project.
