How to re-send campaign based on non-viewed or non-click
If I have a campaign that is an invitation to a survey, how can I resend campaign to those who did not click on the “Start Survey” (only link on page)?
Hi @CAVUCO, I think you’re looking for the segmentation plugin, which allows you to target subscribers based on their interaction with a particular campaign.
Can I apply this to a campaign I already ran? Do I just send the campaign back into edit mode?
Is there a way to delete subscribers that have never opened a campaign sent, seems like all the reconcile subscribers are for other things
Yes. Please see https://resources.phplist.com/plugin/segment
No that’s not necessary [quote=“CAVUCO, post:3, topic:5516”]
[/quote]
Deleting subscribers is hard by design and should ne be necessary. You may be able to do what you want using the subscribers plugin.
Sam,
Thank you for your replies.
I do not see how I can get that tab (segmentation) without sending the campaign back into edit mode. If the campaign has already been sent, it does not appear on the send campaign page. Do I requeue or send the campaign back to the edit mode?
