I revisited the above link but there’s no option to actually delete or remove the key.
Tried searching for the API key in both config files but no luck.
Is this Remote Functionality controllable/editable from the web admin console, the config files or some combination of both. Is the configuration form accessible by manually using the above URL also available from the admin console?
