I have attributes like cell phone, main phone, etc.
I would like to have them formated as they are entered (or stored) to fit the U.S. format like so… (555) 555-1212
Is there a way to do this ?
I am good with html, and fair with php.
using phplist version 3.3.1
PHP 5.6.34
MySQL 5.7.21
@johntrot You should be able to reformat an attribute value by developing a plugin. It needs only to implement one method validateSubscriptionPage(), which can transform $_POST in some way. The method is called when a subscribe page is being displayed (which is probably an error) or submitted. Here is an example supposing that 3 is the id of the attribute that you want to alter .
public function validateSubscriptionPage($pageData)
if (!$_POST) {
return '';
var_dump($_POST);
if (isset($_POST['attribute3'])) {
// transform $_POST['attribute3'] in some way
// $_POST['attribute3'] = $newValue;
return '';
There is more information about developing plugins here https://resources.phplist.com/develop/plugins
Thanks, I will follow-up on your suggestion
