Hi there!
I have a question about the placeholder.
My address list has two fields for salutation.
SALUTATION has:
“Dear sir”
or:
“Dear Mrs”
PERSONAL_SALUTATIOIN has:
“Hello”
What I want to achieve with it:
If “PERSÖNLICHE_SALUTATIOIN” has a value, this should be used first, with the first name, for example:
Hello Christian
If “PERSÖNLICHE_SALUTATIOIN” is empty, the formal salutation should be used, for example:
Dear Mr. Trump
How can I do this with phplist?
I ve seen that there is fallback word. Thats the right direction. I just need instead of a fallback word use a fallback variable. Is this possible?
Thanks for advice!
Best Regards
mailerdaemon
