I am using v3.0.12 of phplist and would appreciate if you could explain how much the delay described as âdelay a bit between messagesâ actually is for DOMAIN_AUTO_THROTTLE?
*# if you have very large numbers of users on the same domains, this may result in the need*
*# to run processqueue many times, when you use domain throttling. You can also tell phplist*
*# to simply delay a bit between messages to increase the number of messages sent per queue run*
*# if you want to use that set this to 1, otherwise simply run the queue many times. A cron*
*# process every 10 or 15 minutes is recommended.*
*define('DOMAIN_AUTO_THROTTLE',1);*
I am currently starting off gently and my settings are as follows.
define("MAILQUEUE_BATCH_SIZE",50);
define("MAILQUEUE_BATCH_PERIOD",600);
define('MAILQUEUE_THROTTLE',10);
define('MAILQUEUE_AUTOTHROTTLE',0);
define('USE_DOMAIN_THROTTLE',0);
define('DOMAIN_BATCH_SIZE',1);
define('DOMAIN_BATCH_PERIOD',120);
define('MAX_PROCESSQUEUE_TIME',0);
I have sent a small message to 3 email addresses within the same domain and it took 31 seconds to process. A 10 second delay is applied between each message which means there canât be any delay being being applied as a consequence of turning on DOMAIN_AUTO_THROTTLE. I turned off USE_DOMAIN_THROTTLE as I found it took 3 process runs to send to the same 3 email addresses (which seems broken to me). With USE_DOMAIN_THROTTLE on it would send 1 email and then report remaining as failed on each process run.
Any guidance gratefully received.
