It appears that DKIM signature got broken if I set EMBEDEXTERNALIMAGES to true in the config file.
Sending a test message with EMBEDEXTERNALIMAGES set to false make DKIM validated, and changing that boolean then sending the same message gives DKIM neutral (body hash did not verify).
Is that normal ??
Tests made with a brand new installation of PHPList (latest version).
T.
