This script will allow you to delete users that are not blacklisted and have a high bouncecount.
I know PHPList already has the ability to do this. HOWEVER, for some unknown reason, it doesn’t get them all.
I do not recommend using this script unless you have decent filters in place for bounce processing.
Make a backup of your DB before playing with this for the first time.
Edit lines 5-10 with your info.
Upload the file to your server.
Use a browser to visit the URL of the script and it will execute.
<?php
// ----- DELETES users with a high bouncecount that are not blacklisted. --------
$servername = "mydomain.com"; //ENTER YOUR DOMAIN NAME
$username = "mydbusername"; //ENTER YOUR DATABASE USERNAME
$password = "mydbpassword"; //ENTER YOUR DATABASE PASSWORD
$dbname = "mydbname"; //ENTER YOUR DATABASE NAME
$dbprefix = "phplist"; //REPLACE WITH YOUR DATABASE PREFIX IF DIFFERENT THAN DEFAULT
$threshold = "10"; //ENTER THE AMOUNT OF BOUNCES THAT USERS WILL BE DELETED FOR HAVING
$conn = mysqli_connect($servername, $username, $password, $dbname);
if (!$conn) {
die("Connection failed: " . mysqli_connect_error());
$query = "SELECT id, email FROM ".$dbprefix."_user_user WHERE bouncecount >= '".$threshold."' AND blacklisted = '0';";
$result = mysqli_query($conn, $query);
if($result === FALSE) {
echo "$query";
} else {
$cnt = 0;
while($row = mysqli_fetch_array($result)){
mysqli_query($conn, "DELETE FROM ".$dbprefix."_user_user WHERE id='$row[id]';");
mysqli_query($conn, "DELETE FROM ".$dbprefix."_user_blacklist WHERE email='$row[email]';");
mysqli_query($conn, "DELETE FROM ".$dbprefix."_user_blacklist_data WHERE email='$row[email]';");
mysqli_query($conn, "DELETE FROM ".$dbprefix."_user_message_bounce WHERE user='$row[id]';");
mysqli_query($conn, "DELETE FROM ".$dbprefix."_user_message_forward WHERE user='$row[id]';");
mysqli_query($conn, "DELETE FROM ".$dbprefix."_user_user_history WHERE user='$row[id]';");
mysqli_query($conn, "DELETE FROM ".$dbprefix."_listuser WHERE userid='$row[id]';");
$cnt = $cnt + 1;
echo "$row[email]<br>";
mysqli_close($conn);
echo "$cnt Addy's expunged for bouncecount over $threshold that are not blacklisted";
