I just saw that some users were well in my database but that they are not registered anywhere. how to export all emails that are not assigned to a list? … I can’t find …
Thank you for your help
The exported file contains information about list membership so, you can also filter it offline.
In phpList I think the easiest way is to create a new list > visit “Subscribers” > “Reconcile Subscribers” and click move all subscribers that don’t belong to any list in the newly created one.
Then you can proceed with the export of the list.
Hope this helps.
i try right away, I keep you posted
it is in progress … and it grinds …
there it’s done
I have 202698 emails in this list…I don’t understand why …
but impossible to export the token time is exceeded
Do you have a solution?
