I have set up the cron based on the instructions in the manual.
#!/bin/bash
/usr/bin/php /var/www/sites/jodywhitesides/lists/admin/index.php -c
/var/www/sites/jodywhitesides/lists/config/config.php $*
when putting in the command: phplist -pprocessqueue, the output I get is: phplist command not found.
how does one go about sussing out this issue?
Actually the proper error Iām getting is:
/var/www/sites/jodywhitesides/lists/config/config.php: Permission denied
Nevermind, it turns out that my file has 3 lines when it should have 2. I fixed that and now the cron works. You can delete this thread please.
p.s. ā it might be a good idea to denote that in the manual. The the /usr/ line is supposed to be one big long line, as it shows it being two lines in the manual.
Thanks; the manual has been updated with a warning about line breaks in that command.
