I’m sure it’s something simple that I have overlooked, but I’m unable to get CKeditor to recognise a customisation .js file.
Path to CKeditor is: plugins/CKEditorPlugin/ckeditor Its working fine.
Path to CKeditor custom configuration file is: plugins/CKEditorPlugin/ckconfig.js This is also correct, but does not work.
I have updated CKeditor to the latest version, 4.4.7_full in the hope that this might help, but it does not.
Can anyone help please?
I am not sure whether a relative path from the phplist directory will work. You should use the path from the web root, something like
/lists/admin/plugins/CKEditorPlugin/ckconfig.js
Otherwise use your browser’s tools to look at the http exchanges and also the javascript log in case there is a syntax error in your file.
In firefox it is Tools > web developer > web console
Many thanks duncan. You were of course quite correct, path from the web root did the trick. Hopefully I’m away now, customise to hearts content!
