Changed links in messages
Just used the remote process queue service and have to say that I am not happy with the results.
Yes, all emails did get sent, and the emails do process correctly, BUT all the links have been changed to tiny-URL formats. I think most recipients would not (and should not!) trust clicking on a link that does not clearly point to its destination. (e.g. "http://www.pointedtodomain.ca’ becomes 'http://www.mydomain.ca/lists/It.php?id=exdrvQwe
Why are the links re-written?
That is the result of click tracking, not really anything to do with the remote queue processing.
You will need to disable click tracking in your config file if you don’t want links to be rewritten like that.
Ah!. Thanks for the quick reply,
I did not realize that. I will change my settings.
