I’ve been having a very frustrated problem the last 2 weeks. I have a 2500+ member list whom I inform of weekly Theatre events in the area. For over a year, I had it throttled back, using these settings (360/hour, seemingly a reasonable figure to avoid being considered spam):
define(“MAILQUEUE_BATCH_SIZE”,60);
define(“MAILQUEUE_BATCH_PERIOD”,600);
define(‘MAILQUEUE_THROTTLE’,2);
Starting with last week’s email, I immediately started getting “Access denied. Your IP address is blacklisted”. I’d wait a while, the error would disappear, and I’d manually restart. Very frustrating. HostGator blamed my ISP (ATT U-Verse), but that was not it: the problem happened from any machine on any wifi network. Talked to HostGator tech last night, and we looked at my phpconfig. I set SIZE & PERIOD back to 200/hour, and he suggested THROTTLE should be 8 seconds. I cranked it back up.
Now the batch doesn’t seem to produce the blacklist error (hard to imagine offending anyone at this throttled, nay, strangled speed ). BUT, the batch, after starting, never proceeds to the next batch. Just sits there with the Cylon back-and-forth “I’m working” status bar, and shows the current message stats. Eg,
Started
Sending in batches of 40 emails
Processing has started, 1 message(s) to process.
Please leave this window open. You have batch processing enabled, so it will reload several times to send the messages. Reports will be sent by email to charlesgpuckett@gmail.com
Processing message 311
Looking for users
Found them: 714 to process
My current settings are:
define(“MAILQUEUE_BATCH_SIZE”,40);
define(“MAILQUEUE_BATCH_PERIOD”,720);
define(‘MAILQUEUE_THROTTLE’,6);
(I pulled back from 8 seconds when the batch stopped proceeding just to see if that had an effect.)
I REALLY need to sort this out. No way I can babysit 2500 list members at 40/pop.
Any suggestions? I’m kinda desperate at the moment.
Tnx,
Chuck Puckett
"I don’t want to steal the show… I only want to borrow it for a while."
