wantig set a cronejob I discovered something from phplist that is there. (ssh?)
I havent set this, it looks like
/var/www/vhosts/istok.de/list.istok.de/admin/index.php -pprocessqueue -c/var/www/vhosts/istok.de/list.istok.de/config/config.php >/dev/null
But when I let it run I get failure alert
Maybe that was, what I have meant that to begin it has worked without a cronejob.
You are missing the ‘php’ command… here’s an example of what you would want…
/usr/bin/php -q /home/useracct/www/html/lists/admin/index.php -p processqueue -c /home/useracct/www/html/lists/config/config.php
or, in the crontab file…
*/6 * * * * root /usr/bin/php -q /home/useracct/www/html/lists/admin/index.php -p processqueue -c /home/useracct/www/html/lists/config/config.php
22 * * * * root /usr/bin/php -q /home/useracct/www/html/lists/admin/index.php -p processbounces -c /home/useracct/www/html/lists/config/config.php
Your directory for the php command, and the path to the index.php and config.php would most likely be different, and therein lies the ‘tricky’ part to setting these up (especially on a virtual machine hosted somewhere like godaddy, etc.).
