I have started an automatic upgrade from 3.5.4 to 3.5.7 but phplist is stuck.
1- first attempt did not work a few days ago : tried to upgrade from 3.5.4 to 3.5.6 did not work. Updater was stuck. I’ve removed the actions.txt file as described in manual.
I have tried to send a campaign but it did not started to send emails. I decided to finish the update process as follow :
2- today I have tried again, auto update from 3.5.4 to 3.5.7 but now updater is locked in the “perform update” stage, with message “Updater is loading” and phplist is in maintenance mode…
in the actions.txt file : {“continue”:false,“step”:10}
What should I do ? simply remove actions.txt , edit the database row “maintencemode” and edit it, changing the value from 1 to 0 ? Something else ?
Thank you for your help.
