I know, that there should be a separate mail for bounce mails. But is there a possibility, that the bounce mail could also be the sending mail. I ve tried it and it works, but as already documented in the documentation, this will empty all mails.
How about, if phplist only removes the mails, which match only the rules and let the other mails in the box as they are so Administrators could add other regex. The positive side is that you can use one mail for everything. If you don’t understand very well: Destination mail = Bounce mail and only emails, which are matched by the rules (550 error for example) get deleted and nothing else in the email box.
Yeah I know, that this is done this way, but I have asked for an “work-around”. But I think there’s no possibility, because the pop command will download all mails to the server and then this will get deleted. Perhaps if they (devs of phplist) would code something like imap for bounces and add a code behavior, that only mails, which match the rule “xyz” will be deleted and not the whole box.
Will look for another setting, if this could work.
// testing things.
$bounce_mailbox_purge = 1;
$bounce_mailbox_purge_unprocessed = 1
