@MarioMey There is actually an explicit test to reject email addresses formatted in this way. I guess that was added because they do look like typing errors. If you want to allow them then you will need to edit a phplist file lists/admin/inc/userlib.php
Look for function is_email(), it is at line 580 in release 3.2.5. Then at line 606 is a comment about rejecting such email addresses. You will need to either amend or delete the following block of code
## fail on emails starting or ending "-" or "." in the pre-at, seems to happen quite often, probably cut-n-paste errors
if (preg_match('/^-/', $email) ||
preg_match('/-@/', $email) ||
preg_match('/\.@/', $email) ||
preg_match('/^\./', $email) ||
preg_match('/^\-/', $email) ||
strpos($email, '\\') === 0
return 0;
