Hello everyone,
I’m trying to get images uploaded when creating a new campaign and it’s been difficult to get them. I have phplist v3.3.4
I get an error 500 message regarding the .htaccess file
I have phplist installed in mailing.domain.com
in /home/user/
This is my file structure inside mailing.domain.com
My config.php has define('UPLOADIMAGES_DIR', 'uploadimages');
My CKeditor config:
URL of ckeditor.js
//cdn.ckeditor.com/4.5.7/full/ckeditor.js
Path to CKeditor custom configuration file
Width in px of CKeditor Area
600
Height in px of CKeditor Area
600
Allow templates to be edited as full HTML pages
Yes
Allow messages to be edited as full HTML pages
No
Path to KCFinder
/admin/plugins/CKEditorPlugin/kcfinder
File system path to the upload image directory. Usually leave this empty.
Name of the image subdirectory of the file upload directory
Name of the files subdirectory of the file upload directory
files
Name of the flash subdirectory of the file upload directory
flash
My kcfinder config:
<?php
/** This file is part of KCFinder project
* @desc Base configuration file
* @package KCFinder
* @version 3.12
* @author Pavel Tzonkov <sunhater@sunhater.com>
* @copyright 2010-2014 KCFinder Project
* @license http://opensource.org/licenses/GPL-3.0 GPLv3
* @license http://opensource.org/licenses/LGPL-3.0 LGPLv3
* @link http://kcfinder.sunhater.com
/* IMPORTANT!!! Do not comment or remove uncommented settings in this file
even if you are using session configuration.
See http://kcfinder.sunhater.com/install for setting descriptions */
$_CONFIG = array(
// GENERAL SETTINGS
'disabled' => true,
'uploadURL' => "upload",
'uploadDir' => "uploadimages",
'theme' => "default",
'types' => array(
// (F)CKEditor types
'files' => "",
'flash' => "swf",
'images' => "*img",
// TinyMCE types
'file' => "",
'media' => "swf flv avi mpg mpeg qt mov wmv asf rm",
'image' => "*img",
// IMAGE SETTINGS
'imageDriversPriority' => "imagick gmagick gd",
'jpegQuality' => 90,
'thumbsDir' => ".thumbs",
'maxImageWidth' => 0,
'maxImageHeight' => 0,
'thumbWidth' => 100,
'thumbHeight' => 100,
'watermark' => "",
// DISABLE / ENABLE SETTINGS
'denyZipDownload' => false,
'denyUpdateCheck' => false,
'denyExtensionRename' => false,
// PERMISSION SETTINGS
'dirPerms' => 0755,
'filePerms' => 0644,
'access' => array(
'files' => array(
'upload' => true,
'delete' => true,
'copy' => true,
'move' => true,
'rename' => true
'dirs' => array(
'create' => true,
'delete' => true,
'rename' => true
'deniedExts' => "exe com msi bat cgi pl php phps phtml php3 php4 php5 php6 py pyc pyo pcgi pcgi3 pcgi4 pcgi5 pchi6",
// MISC SETTINGS
'filenameChangeChars' => array(/*
' ' => "_",
'dirnameChangeChars' => array(/*
' ' => "_",
'mime_magic' => "",
'cookieDomain' => "",
'cookiePath' => "",
'cookiePrefix' => 'KCFINDER_',
// THE FOLLOWING SETTINGS CANNOT BE OVERRIDED WITH SESSION SETTINGS
'_normalizeFilenames' => false,
'_check4htaccess' => false,
//'_tinyMCEPath' => "/tiny_mce",
'_sessionVar' => "KCFINDER",
//'_sessionLifetime' => 30,
//'_sessionDir' => "/full/directory/path",
//'_sessionDomain' => ".mysite.com",
//'_sessionPath' => "/my/path",
//'_cssMinCmd' => "java -jar /path/to/yuicompressor.jar --type css {file}",
//'_jsMinCmd' => "java -jar /path/to/yuicompressor.jar --type js {file}",
My uploadimages
directory structure:
uploadimages
--> image
--> files
--> flash
What should I do in order to get the images loaded?
This is the url from the popup browser window which return error 500:
http://mailing.domain.com/admin/plugins/CKEditorPlugin/kcfinder/browse.php?opener=ckeditor&type=image&CKEditor=message&CKEditorFuncNum=1&langCode=en
