But it won’t send any message out. No test message nothing. Without setuped SMTP it send messages out.
I tried the same date into outlook and it works fine. So the data are correct.
@Pro-Webs.de You can enable the smtp debug setting in config.php then send a test email. There will be some output at the top of the page that should explain what is not working.
Sorry for that count of unnecessary posts …
I don’t know why he tell me that he want to send via info mail … on the compain setting and also on the message in From is no-reply written …
Also tried to set this:
define(‘USE_ADMIN_DETAILS_FOR_MESSAGES’,0);
Yes it is a real account. As I said I have also tried the account data on outlook and it works. However as I see it try to send the mail over info and not over no-reply? I don’t understand why. I have explicit written no-reply in campain konfiguration and also on the message creation in FROM field.
@Pro-Webs.de when copying/pasting the output use the </> button on the toolbar so that it is treated as plain text.
The MAIL FROM address is the value of $message_envelope in the config.php file.
I think that you need to raise this with your hosting company to find out why it is being rejected.
I’m not sure what you mean. I don’t have set a value for $message_envelope in config.php file.
Now i have done this and it look like it works now.
But i still don’t understand why this is necessary and is placed on topic “Settings for handling bounces” of phpList and not by smtp settings … if it is required for…
