Thanks Angel. This is my config.php
// what is your Mysql database server hostname
$database_host = ‘localhost’;
// what is the name of the database we are using
$database_name = ‘databasedb’;
// what user has access to this database
$database_user = database
// and what is the password to login to control the database
$database_password = ‘xxxxxxxxx’;
//# if your SMTP server is called “smtp.mydomain.com” you enter this below like this:
//# define(“PHPMAILERHOST”,‘smtp.mydomain.com’);
define(‘PHPMAILERHOST’, ‘mail.domain.es’);
$phpmailer_smtpuser = ‘webmaster@domain.es’;
$phpmailer_smtppassword = ‘xxxxxxxx’;
define(‘PHPMAILERPORT’,‘25’);
$phpmailer_smtpoptions = array(
‘ssl’ => array(
‘verify_peer’ => false,
‘verify_peer_name’ => false,
‘allow_self_signed’ => true
// this is here, to make sure you edited the config file and mails are not sent “accidentally”
// on unmanaged systems
define(‘TEST’, 0);
- Settings for handling bounces
- This section is OPTIONAL, and not necessary to send out mailings, but it is highly recommended to correctly
- set up bounce processing. Without processing of bounces your system will end up sending large amounts of
- unnecessary messages, which overloads your own server, the receiving servers and internet traffic as a whole
// Message envelope.
// This is the address that most bounces will be delivered to
// Your should make this an address that no PERSON reads
// but a mailbox that phpList can empty every so often, to process the bounces
$message_envelope = ‘listbounces@domain.es’;
// This can be ‘pop’ or ‘mbox’
$bounce_protocol = ‘pop’;
// commandline
define(‘MANUALLY_PROCESS_BOUNCES’, 0);
define (“MANUALLY_PROCESS_QUEUE”,0);
define(‘BLACKLIST_EMAIL_ON_BOUNCE’, 1);
define(‘USE_ADVANCED_BOUNCEHANDLING’,1);
$bounce_mailbox_host = ‘localhost’;
$bounce_mailbox_user = ‘listbounces@domain.es’;
$bounce_mailbox_password = ‘xxxxxxxxx’;
// the “port” is the remote port of the connection to retrieve the emails
// the default should be fine but if it doesn’t work, you can try the second
// second line
$bounce_mailbox_port = ‘110/pop3/notls’;
//$bounce_mailbox_port = “110/pop3”;
// it’s getting more common to have secure connections, in which case you probably want to use
//$bounce_mailbox_port = “995/pop3/ssl/novalidate-cert”;
// when the protocol is mbox specify this one
// it needs to be a local file in mbox format, accessible to your webserver user
$bounce_mailbox = ‘/var/mail/listbounces’;
// testing things.
$bounce_mailbox_purge = 1;
// how many bounces in a row need to have occurred for a user to be marked unconfirmed
// choose the hash method for password
// check the extended config for more info
// in most cases, it is fine to leave this as it is
define(‘HASH_ALGO’, ‘sha256’);
// define the amount of emails you want to send per period. If 0, batch processing
// is disabled and messages are sent out as fast as possible
define(‘MAILQUEUE_BATCH_SIZE’, 300);
// define the length of one batch processing period, in seconds (3600 is an hour)
define(‘MAILQUEUE_BATCH_PERIOD’, 3600);
// to avoid overloading the server that sends your email, you can add a little delay
// between messages that will spread the load of sending
// you will need to find a good value for your own server
// value is in seconds, and you can use fractions, eg “0.5” is half a second
// (or you can play with the autothrottle below)
define(‘MAILQUEUE_THROTTLE’, 6);
// if you use login, how many lists can be created per administrator
define(‘MAXLIST’, 100);
define(“EXPORT_EXCEL”,1);
$default_system_language = “es”;
$language_module = “spanish.inc”;
define(“ALLOW_ATTACHMENTS”,1);
define(“NUMATTACHMENTS”,1);
$attachment_repository = ‘/var/www/vhosts/domain.es/httpdocs/tmp’;
$pageroot = ‘’;
// if you activate the check above, you can add domain names in this array for those domains
// that you trust and that can be allowed as well
// only mention the domain for each.
// for example: $allowed_referrers = array(‘mydomain.com’,‘msn.com’,‘yahoo.com’,‘google.com’);
$allowed_referrers = array(‘otherdomain.es’);
# test emails
# if you send a test email, phplist will by default send you two emails, one in HTML format
# and the other in Text format. If you set this to 1, you can override this behaviour
# and only have a test email sent to you that matches the user record of the user that the
# test emails are sent to
define('SEND_ONE_TESTMAIL', 0);
