phpList 3.3.8 Release Candidate ready for testing
A Release Candidate for the upcoming phpList 3.3.8 is available for testing, including a redesigned dashboard that conveniently summarises your campaign statistics, and provides easy access to the phpList manual. Other fixes and improvements include:
  • Added option to the phpList config file to enable / disable the Automatic updater
  • Change the number of "recently visited" pages from 6 to 3 for easier navigation
  • Fixed false "Success" message when Saving new template with the same name fails
  • Fixed Command line signature displayed twice
For the full list of changes see the roadmap for this version.
Automatic updater
This is your opportunity to use the Automatic Updater, released last month, for the first time, to upgrade from 3.3.7 to this Release Candidate. Please test the updater to find issues on your particular platform and setup so they can be addressed before all other phpList users upgrade to 3.3.8 at the end of this week.
Download the Release Candidate here if you are running a version older than 3.3.7-RC1.
Guidelines
Upgrade from older releases following the usual upgrade process
Use your phpList as normal, and report any new problems you find
Reporting issues
Report any issues you find to the phpList Bugtracker, selecting “3.3.8-RC1” as the Product Version
Happy testing!
