Is the latest version of PHPList compatible with MariaDB 10.2 ? I am currently running MariaDB 10.1, and see this warning when I go to upgrade:
MariaDB enables “strict mode” by default as of version 10.2. Strict mode controls how MariaDB and MySQL handle invalid or missing values in data-change statements such as INSERT or UPDATE. Applications not built with strict mode enabled may cause undesired behavior; please verify applications using MariaDB are compatible before upgrading. More information about strict mode is available here
So you definitely know more than I do about this…and I hope your take here is correct, as there is, according to Cpanel’s warnings, no way of downgrading once I upgrade.
So it looks as though I need strict mode enabled, or perhaps it is by default? I will check for a setting in the ACP. Thank you!
