Tracking links are working as expected with html email except when an image map is used. In this case the link(s) are not converted to tracking links. Any ideas or suggestions for a fix or workaround? Thank you.
Unfortunately this appears to be a long-standing feature request (loooong…) https://mantis.phplist.org/view.php?id=6611
Your best bet at this stage is to work on implementing it yourself, or sponsoring someone else to do it.
Thank you – appreciate the quick response and good info.
@headalien @samtuke There is a config file setting that looks to be necessary but I don’t understand to exactly what value it would need to be set
https://resources.phplist.com/system/config/clicktrack_linkmap
