Here my first newby question: How do I send a Campaign right away? I mean, not schedule it but sent it right away.
Thanks.
Thanks.
You would want to create your message, select a list to send it to, and then submit the message to the queue. Then you want to process the queue. It should go immediately. There are menus for processing the queue, which you would use, unless you have cron jobs set to send automatically.
If it doesn’t go, make sure the timezone settings for php are the set to the same settings as the timezone setting of your server. There is a ‘time zone’ plugin that will help you do this, if you don’t know how.
Got it. Thanks.
Unless I set the time, the message will be send right away.
