Simply add the following line to your phplist/config/config.php file
# if you change the path to the phpList system, make the change here as well
$pageroot = '/phplist';
I have install PHPList in the repertory : www.mydomain.yyy/Newsletters/lists/
PHPList works but when you click to do an action, the adress of return is not “www.mydomain.yyy/Newsletters/lists/admin” but “www.mydomain.yyy/lists/admin” with the error 404 :
> Not Found > The requested URL /lists/admin/ was not found on this server. > Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
For example :
I go to “List of campaigns” -> “Active” -> in the list of campaign, click on the button “suspend”
==> the campaign is well suspended, but I have the message error 404…
PHPList does not generate a good address of return.
